Installation errors: sh I/O Error
hellbender
Post by hellbender »
System: Ubuntu 16.04 LTS - fresh installed
At my first installation there had bee some installation errors. I got it and it revealed that issue was that sudo was missing.
Maybe the installer coud make sure sudo is installed. I furthermore must admit, that my installation procedure is not exactly the standard type of installed. I installed via FAI.
Regards,
Tobias
Re: Installation errors: sh I/O Error
To be more fail-save with different types of OS images, the next KeyHelp installation for Ubuntu 16 will install sudo explicitly.
Thanks for reporting.
