Letsencrypt Cert for server domain  [SOLVED]
gusarg81
Post by gusarg81 »
I see that is not possible to add Letsencrypt SSL Certificate via KeyHelp panel on server domain (in my case, server.gdnet.ar, which is configure in hostname and the server itself, including postfix, etc).
I will have to do this manually or the is a way via KeyHelp? Thanks.
Re: Letsencrypt Cert for server domain
go to KeyHelp admin area -> Security -> SSL/TLS Certificates -> Click on the button "Secure server services" -> Select "Let's Encrypt".
gusarg81
Re: Letsencrypt Cert for server domain  [SOLVED]
Post by gusarg81 »
Thanks! Found it. Without remember, it seems I already did that :D
After a fresh KeyHelp installation, KeyHelp is trying to aquire a Lets Encrypt certificate on its own / without being requested - it takes care of its users :D.
gusarg81
Post by gusarg81 »
Haha, I can see that! Very well done by the way!
So far my migration from i-MSCP to KeyHelp was success. Thanks a lot and congrats for this piece of software. I am developer myself (Python/Django/PySIde) and I must say, it is far the best Hosting Panel I've ever tested. All the details, very well polished.
Thanks.
