default language  [SOLVED]
tom83
default language
Post by tom83 »
Is there any way to make a language default? Istead of always have to change the from English to the other language, is possible to just mark the default and would always be selected?
Thanks.
nikko
Re: default language
Post by nikko »
The user can choose the preferred language. (top right corner)
tom83
Post by tom83 »
Nice. I know.
But all clients will be in the same country. Is possible to make any language default? Or take off other languages?
Cheers.
nikko
Re: default language  [SOLVED]
Post by nikko »
Sure.
Login as admin, go to "Configuration" -> "Appearance" -> "Languages" and set your preferred language as default.
More about you can find here: https://doc.keyhelp.de/switch/?lang=en
