In the panel as user Admin, I set the user permissions to have SSH permissions
What does it mean ?
Can the user (when the user logs into the user panel), have a SSH link to his terminal ?
I am attaching a screenshot
How to enable a user to SSH in his panel
Re: How to enable a user to SSH in his panel
It enables the user to connect to SSH on the server, by any means they choose.
They could connect by using terminal command:
or by using a program like Filezilla.
ssh user@1.2.3.4
Ohh, I see
I will have to try that
Thank you for your quick reply George!
Chaiavi
Chaiavi
