Einen Überblick über das Administrationstool KeyHelp der Keyweb AG und dessen Download gibt es auf https://www.keyhelp.de
Dieses Forum soll es interessierten Benutzern ermöglichen, sich über KeyHelp auszutauschen und Hilfe bei Problemen zu finden.
phpMyAdmin Fail to update to 5.1.0
You found a bug? Please tell us about.
Antworten
Tony20
Beitrag von Tony20 »
The recent KeyHelp update fail to update phpMyAdmin 4.9.7 to 5.1.0
panelupdate.log
[17-Mar-2021 02:39:33] INFO --> [phpMyAdmin] update to version 5.1.0
[17-Mar-2021 02:42:29] ERROR --> [phpMyAdmin] failed to download and extract, we try again in a few seconds...
[17-Mar-2021 02:44:51] ERROR --> [phpMyAdmin] failed to download and extract, we try again in a few seconds...
[17-Mar-2021 02:48:07] ERROR --> [phpMyAdmin] failed to download and extract, we try again in a few seconds...
[17-Mar-2021 02:48:27] ERROR --> [phpmyadmin] failed to update, version remains the same.
[17-Mar-2021 02:48:27] INFO --> [roundcube] update to version 1.4.11
[17-Mar-2021 02:50:37] ERROR --> [roundcube] failed to download and extract, we try again in a few seconds...
[17-Mar-2021 02:52:44] INFO --> [roundcube] setup configuration files
[17-Mar-2021 02:52:44] INFO --> [roundcube] update complete
[17-Mar-2021 02:52:44] INFO --> [rainloop] update to version 1.15.0
[17-Mar-2021 02:54:21] INFO --> [rainloop] update complete
[17-Mar-2021 02:54:22] INFO --> unlock panel
[17-Mar-2021 02:54:22] INFO --> update process finished, you are now running on version "21.0"
[17-Mar-2021 02:54:22] INFO --> set correct tmp-directories mount for normal behavior
My server OS is Ubuntu 20.04 (64-bit) everything is up-to date
Antworten
