Email forwarding without a mailbox  [SOLVED]
shoulders
Post by shoulders »
When you are setting up an email address you have the ability to forward all 'specified' emails onwards but you still have to have a mailbox even if you are not storing the forwarded emails.
Is it possible to have email forwarding without the need of a mailbox?
This is not a biggie because I can just set the mailbox to a very small size. My one followup to this question is; Does the mailbox have to be big enough to hold that single email before it is forwarded, or is the mailbox actually skipped in this instance?
If the mailbox is skipped I will just set it to 1mb.
Re: Email forwarding without a mailbox
no, as long as you not activate the checkbox "Store forwarded emails in the mailbox as well" there is no mailbox
