Problem mit xtables-addons  [SOLVED]
Fiesi
Post by Fiesi »
viell kann mir hier jemand weiter helfen ;)
Bei Proxmox drüben reagiert leider keiner ;)
Ich versuche seit Tagen schon xtables-addons unter den PVE Kernel zu installieren.
Leider immer vergebens.
Evtl. hat hier jemand ja mal ein Tip oder Lösung parat.
 apt-get install xtables-addons-dkms
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  xtables-addons-dkms
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/284 kB of archives.
After this operation, 1,606 kB of additional disk space will be used.
Selecting previously unselected package xtables-addons-dkms.
(Reading database ... 174078 files and directories currently installed.)
Preparing to unpack .../xtables-addons-dkms_2.12-0.1_all.deb ...
Unpacking xtables-addons-dkms (2.12-0.1) ...
Setting up xtables-addons-dkms (2.12-0.1) ...
Loading new xtables-addons-2.12 DKMS files...
Building for 4.15.17-3-pve
Building initial module for 4.15.17-3-pve
Error!  Build of xt_ACCOUNT.ko failed for: 4.15.17-3-pve (x86_64)
Consult the make.log in the build directory
/var/lib/dkms/xtables-addons/2.12/build/ for more information.
root@host /tmp #
und hier war ein anderer Versuch:
root@host /usr/src # module-assistant --verbose --text-mode auto-install xtables-addons
xtables-addons
Updating info about xtables-addons-source
Updated infos about 1 packages
Getting source for kernel version: 4.15.17-3-pve
Kernel headers available in /usr/src/linux-headers-4.15.17-3-pve
Creating symlink...
apt-get install build-essential
build-essential is already the newest version (12.3).
Done!
unpack
Removing old /usr/src/modules/xtables-addons/ tree
 rm -rf /usr/src/modules/xtables-addons
Extracting the package tarball, /usr/src/xtables-addons.tar.bz2, please wait...
 tar --bzip2 -x -f /usr/src/xtables-addons.tar.bz2
"/usr/share/modass/packages/default.sh" build KVERS=4.15.17-3-pve KSRC=/usr/src/linux kdist_image
 debian/rules kdist_clean
/usr/bin/make -C /usr/src/linux M=/usr/src/modules/xtables-addons/extensions XA_ABSTOPSRCDIR=/usr/src/modules/xtables-addons XA_TOPSRCDIR=/usr/src/modules/xtables-addons DEPMOD=/bin/true clean
make[1]: Entering directory '/usr/src/linux-headers-4.15.17-3-pve'
make[1]: Leaving directory '/usr/src/linux-headers-4.15.17-3-pve'
dh_prep
dh_clean
 debian/rules KVERS=4.15.17-3-pve KSRC=/usr/src/linux kdist_image
/usr/bin/make  -f debian/rules kdist_clean kdist_config binary-modules
make[1]: Entering directory '/usr/src/modules/xtables-addons'
make[2]: Entering directory '/usr/src/linux-headers-4.15.17-3-pve'
make[2]: Leaving directory '/usr/src/linux-headers-4.15.17-3-pve'
dh_prep
dh_clean
for templ in ; do \
    cp $templ `echo $templ | sed -e 's/_KVERS_/4.15.17-3-pve/g'` ; \
  done
for templ in `ls debian/*.modules.in` ; do \
    test -e ${templ%.modules.in}.backup || cp ${templ%.modules.in} ${templ%.modules.in}.backup 2>/dev/null || true; \
    sed -e 's/##KVERS##/4.15.17-3-pve/g ;s/#KVERS#/4.15.17-3-pve/g ; s/_KVERS_/4.15.17-3-pve/g ; s/##KDREV##//g ; s/#KDREV#//g ; s/_KDREV_//g  ' < $templ > ${templ%.modules.in}; \
  done
dh binary-arch
   dh_testdir -a
   dh_update_autotools_config -a
   dh_auto_configure -a
   debian/rules override_dh_auto_build
make[2]: Entering directory '/usr/src/modules/xtables-addons'
dh_auto_build -- -C /usr/src/linux M=/usr/src/modules/xtables-addons/extensions XA_ABSTOPSRCDIR=/usr/src/modules/xtables-addons XA_TOPSRCDIR=/usr/src/modules/xtables-addons DEPMOD=/bin/true
        make -j1 -C /usr/src/linux M=/usr/src/modules/xtables-addons/extensions XA_ABSTOPSRCDIR=/usr/src/modules/xtables-addons XA_TOPSRCDIR=/usr/src/modules/xtables-addons DEPMOD=/bin/true
make[3]: Entering directory '/usr/src/linux-headers-4.15.17-3-pve'
  CC [M]  /usr/src/modules/xtables-addons/extensions/compat_xtables.o
  CC [M]  /usr/src/modules/xtables-addons/extensions/xt_CHAOS.o
  CC [M]  /usr/src/modules/xtables-addons/extensions/xt_DELUDE.o
  CC [M]  /usr/src/modules/xtables-addons/extensions/xt_DHCPMAC.o
  CC [M]  /usr/src/modules/xtables-addons/extensions/xt_DNETMAP.o
/usr/src/modules/xtables-addons/extensions/xt_DNETMAP.c: In function ‘dnetmap_tg’:
/usr/src/modules/xtables-addons/extensions/xt_DNETMAP.c:380:2: error: implicit declaration of function ‘NF_CT_ASSERT’ [-Werror=implicit-function-declaration]
  NF_CT_ASSERT(hooknum == NF_INET_POST_ROUTING ||
cc1: some warnings being treated as errors
scripts/Makefile.build:331: recipe for target '/usr/src/modules/xtables-addons/extensions/xt_DNETMAP.o' failed
make[4]: *** [/usr/src/modules/xtables-addons/extensions/xt_DNETMAP.o] Error 1
Makefile:1552: recipe for target '_module_/usr/src/modules/xtables-addons/extensions' failed
make[3]: *** [_module_/usr/src/modules/xtables-addons/extensions] Error 2
make[3]: Leaving directory '/usr/src/linux-headers-4.15.17-3-pve'
dh_auto_build: make -j1 -C /usr/src/linux M=/usr/src/modules/xtables-addons/extensions XA_ABSTOPSRCDIR=/usr/src/modules/xtables-addons XA_TOPSRCDIR=/usr/src/modules/xtables-addons DEPMOD=/bin/true returned exit code 2
debian/rules:51: recipe for target 'override_dh_auto_build' failed
make[2]: *** [override_dh_auto_build] Error 2
make[2]: Leaving directory '/usr/src/modules/xtables-addons'
debian/rules:48: recipe for target 'binary-modules' failed
make[1]: *** [binary-modules] Error 2
make[1]: Leaving directory '/usr/src/modules/xtables-addons'
/usr/share/modass/include/common-rules.make:56: recipe for target 'kdist_build' failed
make: *** [kdist_build] Error 2
BUILD FAILED!
See /var/cache/modass/xtables-addons-source.buildlog.4.15.17-3-pve.1529326287 for details.
Build failed. Press Return to continue...
Danke erstmal...
Edit:
Habs hinbekommen ;)
Hab einfach die addons aus SID installiert - nun lief installation durch
