woran liegt das genau? Habe es versucht neu zu installieren, bin Anfänger
● clamav-daemon.service - Clam AntiVirus userspace daemon
Loaded: loaded (/lib/systemd/system/clamav-daemon.service; disabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/clamav-daemon.service.d
└─extend.conf
Active: failed (Result: exit-code) since Sun 2021-01-31 12:18:20 UTC; 2min 28s ago
Docs: man:clamd(8)
man:clamd.conf(5)
https://www.clamav.net/documents/
Process: 5181 ExecStart=/usr/sbin/clamd --foreground=true (code=exited, status=1/FAILURE)
Process: 5178 ExecStartPre=/bin/chown clamav /run/clamav (code=exited, status=0/SUCCESS)
Process: 5172 ExecStartPre=/bin/mkdir /run/clamav (code=exited, status=1/FAILURE)
Main PID: 5181 (code=exited, status=1/FAILURE)
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: LibClamAV Error: cli_ac_addpatt: Can't allocate memory for new->tr
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: LibClamAV Error: cli_parse_add(): Problem adding signature (3).
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: LibClamAV Error: Problem parsing database at line 11687
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: LibClamAV Error: Can't load daily.ldb: Can't allocate memory
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: LibClamAV Error: cli_tgzload: Can't load daily.ldb
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: LibClamAV Error: Can't load /var/lib/clamav/daily.cvd: Malformed d
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: LibClamAV Error: cli_loaddbdir(): error loading database /var/lib/
Jan 31 12:18:19 cp.cuetv.cc clamd[5181]: Sun Jan 31 12:18:19 2021 -> !Malformed database
Jan 31 12:18:20 cp.cuetv.cc systemd[1]: clamav-daemon.service: Main process exited, code=exited, status=1/F
Jan 31 12:18:20 cp.cuetv.cc systemd[1]: clamav-daemon.service: Failed with result 'exit-code'.
lines 1-23
