[REQUEST] ModSecurity
benkhouya
Post by benkhouya »
It will be a great plus for KeyHelp if you add an option for installing and managing ModSecurity using the web interface of your panel.
PS. Thank you very much for your good work!
nikko
Re: [REQUEST] ModSecurity
Post by nikko »
At the moment U can use it manually.
After install pls. check the logfiles and rules - and disable with
SecRuleRemoveById xxxxxx, xxxxxx
in /etc/apache2/mods-enabled/@security2.conf the rules, which blocking keyhelp.
I think it's a planned feature...
benkhouya
Post by benkhouya »
Thank you for your answer, and I sincerely hope it will be included in the KeyHelp panel soon.
