SSL Zertifikat wird nicht ausgestellt  [GELÖST]
queermeet
Post by queermeet »
ja
Debian 12
Proxmox
25.0 (Build 3398)
Beim Ausstellen des Zertifikats kommt ein Fehler
Log Ausschnitt:
\[2025-05-09 10:21:01] INFO | starting ssl certification maintenance
\[2025-05-09 10:21:01] INFO | checking (normal) SSL/TLS certificates
\[2025-05-09 10:21:01] INFO | check certificate "\[ID 1]"
\[2025-05-09 10:21:01] INFO | certificate name is "default"
\[2025-05-09 10:21:01] INFO | certificate is valid until 2035-05-06 17:14:39 (3649 days left)
\[2025-05-09 10:21:01] INFO | checking lets encrypt certificates
\[2025-05-09 10:21:01] INFO | remove unused accounts / certificates
\[2025-05-09 10:21:01] INFO | check domain "queermeet.de'
\[2025-05-09 10:21:01] INFO | certificate file does not exist
\[2025-05-09 10:21:01] INFO | renew cert
\[2025-05-09 10:21:01] INFO | Using certificate authority: "[https://acme-v02.api.letsencrypt.org/](https://acme-v02.api.letsencrypt.org/)" (PRODUCTION).
\[2025-05-09 10:21:01] INFO | Getting endpoint URLs.
\[2025-05-09 10:21:02] INFO | Account "mrcrossii" already registered. Continue.
\[2025-05-09 10:21:02] INFO | Requesting Key ID.
\[2025-05-09 10:21:02] INFO | Sending signed request to "[https://acme-v02.api.letsencrypt.org/acme/new-acct](https://acme-v02.api.letsencrypt.org/acme/new-acct)".
\[2025-05-09 10:21:03] INFO | Start certificate generation.
\[2025-05-09 10:21:03] INFO | Token stored at: /home/keyhelp/www/.well-known/acme-challenge/local-check-681dbaef590ef2.87272567
\[2025-05-09 10:21:03] INFO | URL: [http://queermeet.de/.well-known/acme-ch ... 2.87272567](http://queermeet.de/.well-known/acme-ch ... 2.87272567) | HTTP code: 404 | HTTP body (first 100 chars): <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">\<h
\[2025-05-09 10:21:03] ERROR | a Let's Encrypt error occurred: Local resolving checks failed for domain "queermeet.de". Please ensure that your domain is locally resolvable!
\[2025-05-09 10:21:03] INFO | check domain "[www.queermeet.de](http://www.queermeet.de)'
\[2025-05-09 10:21:03] INFO | certificate file does not exist
\[2025-05-09 10:21:03] INFO | renew cert
\[2025-05-09 10:21:03] INFO | Using certificate authority: "[https://acme-v02.api.letsencrypt.org/](https://acme-v02.api.letsencrypt.org/)" (PRODUCTION).
\[2025-05-09 10:21:03] INFO | Getting endpoint URLs.
\[2025-05-09 10:21:03] INFO | Account "mrcrossii" already registered. Continue.
\[2025-05-09 10:21:03] INFO | Requesting Key ID.
\[2025-05-09 10:21:03] INFO | Sending signed request to "[https://acme-v02.api.letsencrypt.org/acme/new-acct](https://acme-v02.api.letsencrypt.org/acme/new-acct)".
\[2025-05-09 10:21:04] INFO | Start certificate generation.
\[2025-05-09 10:21:04] INFO | Token stored at: /home/keyhelp/www/.well-known/acme-challenge/local-check-681dbaf0c602f7.49538345
\[2025-05-09 10:21:04] INFO | URL: [http://www.queermeet.de/.well-known/acm ... 7.49538345](http://www.queermeet.de/.well-known/acm ... 7.49538345) | HTTP code: 404 | HTTP body (first 100 chars): <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">\<h
\[2025-05-09 10:21:04] ERROR | a Let's Encrypt error occurred: Local resolving checks failed for domain "[www.queermeet.de](http://www.queermeet.de)". Please ensure that your domain is locally resolvable!
\[2025-05-09 10:21:04] INFO | check domain "mrcrossii.de'
\[2025-05-09 10:21:04] INFO | certificate file does not exist
\[2025-05-09 10:21:04] INFO | renew cert
\[2025-05-09 10:21:04] INFO | Using certificate authority: "[https://acme-v02.api.letsencrypt.org/](https://acme-v02.api.letsencrypt.org/)" (PRODUCTION).
\[2025-05-09 10:21:04] INFO | Getting endpoint URLs.
\[2025-05-09 10:21:05] INFO | Account "mrcrossii" already registered. Continue.
\[2025-05-09 10:21:05] INFO | Requesting Key ID.
\[2025-05-09 10:21:05] INFO | Sending signed request to "[https://acme-v02.api.letsencrypt.org/acme/new-acct](https://acme-v02.api.letsencrypt.org/acme/new-acct)".
\[2025-05-09 10:21:06] INFO | Start certificate generation.
\[2025-05-09 10:21:06] INFO | Token stored at: /home/keyhelp/www/.well-known/acme-challenge/local-check-681dbaf22d2949.45568155
\[2025-05-09 10:21:06] INFO | URL: [http://mrcrossii.de/.well-known/acme-ch ... 9.45568155](http://mrcrossii.de/.well-known/acme-ch ... 9.45568155) | HTTP code: 404 | HTTP body (first 100 chars): <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">\<h
\[2025-05-09 10:21:06] ERROR | a Let's Encrypt error occurred: Local resolving checks failed for domain "mrcrossii.de". Please ensure that your domain is locally resolvable!
\[2025-05-09 10:21:06] INFO | check domain "[www.mrcrossii.de](http://www.mrcrossii.de)'
\[2025-05-09 10:21:06] INFO | certificate file does not exist
\[2025-05-09 10:21:06] INFO | renew cert
\[2025-05-09 10:21:06] INFO | Using certificate authority: "[https://acme-v02.api.letsencrypt.org/](https://acme-v02.api.letsencrypt.org/)" (PRODUCTION).
\[2025-05-09 10:21:06] INFO | Getting endpoint URLs.
Re: SSL Zertifikat wird nicht ausgestellt
die Domains zeigen korrekt auf den Server? Hast du geprüft, dass der Server die Domains richtig auflösen kann?
Re: SSL Zertifikat wird nicht ausgestellt  [GELÖST]
hast du das denn überprüft?
Einfach mal AUF DEM SERVER mittels z.B. wget, curl o.Ä. versuchen, die Domain zu erreichen, bzw. diese URL:
http://queermeet.de/.well-known/acme-challenge/local-check-681dbaef590ef2.87272567
queermeet
Post by queermeet »
Wir haben gestern eine Umstellung auf einen anderen Server gemacht, aber das DNS Lookup zeigt bereits auf die richtigen Server und ich kann die Domain auch aufrufen über meinen Browser
Hier auch direkt mit test.php im root Verzeichnis der Domain
http://queermeet.de/test.php
Wenn ich die Domain http://queermeet.de/.well-known/acme-ch ... 2.87272567
aufrufe zeigt mir das System an:
du musst die URL mal auf Deinem Server aufrufen.
Es kann ferner auch noch etwas dauern bis Let's Encpryt die DNS Änderung übernommen hat.
queermeet
Post by queermeet »
Ja, scheint wohl so, denn beim Aufruf über curl im Terminal findet der Server noch die alte Liveconfig "Domain nicht gefunden" Seite
queermeet
Post by queermeet »
Ich hab nochmal eine Frage, ich bin nämlich neu in der Netzwerktechnik
warum wird der token unter/home/keyhelp/www/.well-known/acme-challenge/local-check-681dffe229cc86.38720675 gespeichert, obwohl meine Domain unter /home/users/mrcrossii/www/queermeet.de liegt?
Ich verstehen nicht so ganz, wie ich dann über http://www.queermeet.de/.well-known/acm ... 6.38720675 den Check über den Server richtig aufrufen soll?
queermeet
Post by queermeet »
und was ich auch nicht verstehe:
wenn ich queermeet.de direkt aufrufe oder auch über https://dnschecker.org/ prüfe, wird auf allen Servern der richtie IP und NS Eintrag erkannt, aber warum zeigt curl immer noch die alte Version an, wenn ich die local-check Domain aufrufe?
Die Antwort liegt in dieser Datei:
/etc/apache2/conf-available/acme.conf
# KeyHelp webserver config file for Apache 2.4
Alias "/.well-known/acme-challenge" "/home/keyhelp/www/.well-known/acme-challenge"
<Directory "/home/keyhelp/www/.well-known/acme-challenge">
    Require all granted
</Directory>
Dies erzeugt für jede Domain auf dem Server einen Alias für die URL <DOMAIN-NAME>/.well-known/acme-challenge der auf Dateiebene auf diesen Ordner zeigt: /home/keyhelp/www/.well-known/acme-challenge
Wenn ich das nicht machen würde, müsste ich immer wenn ein Let's Encrypt Zertifikat beantragt werden soll, in den Dateien der Nutzer herumpfuschen und diesen Ordner manuell erstellen und das wäre für alle Beteiligten äußerst unschön ;).
queermeet
Post by queermeet »
Ah okay, danke.
Aber ich verstehe trotzdem nicht, warum nach mittlerweile 24 Stunden die curl Antwort im terminal auf dem Server immer noch den alten HTML Output des alten Servers anzeigt
Wie gesagt, ich habe 3 Seiten ausprobiert, die NS und A Einträge anzeigen und alle Server, egal ob Deutsche oder irgendwelche im Ausland zeigen alle die Richtige IP und den richtigen NS an, ist doch irgendwie komisch
welche Nameserver nutzt Dein Server für resolving?
Du kannst übrigens auch temporär die Lokale Überprüfung deaktivieren:
Im KeyHelp -> Konfiguration -> SSL/TLS-Zertifikate -> Lokale Prüfungen der Domain-Namen-Auflösung durchführen -> Einstellung deaktivieren
Sofern die DNS-Einstellungen bei Let's Encrypt schon aktuell sind, solltest du das Zertifikat beziehen können. Das Problem der lokalen Auflösung solltest du dann aber trotzdem beheben (und die oben genannte Option dann wieder aktivieren).
queermeet
Post by queermeet »
@Florian:
Ich nutze die meines Server-Anbieters
dns51.cloudns.net.
dns52.cloudns.net.
dns53.cloudns.net.
dns54.cloudns.net.
@Alexander:
danke, das hat geholfen, ich habe das Zertifikat bekommen
