issues with backup and lock  [SOLVED]
RikkerdNL
Post by RikkerdNL »
Maybe it is in Restic, but using the native backup feature of Keyhelp.
Ubuntu Linux 24.04.3
25.3 (Build 3565)
We have setup keyhelp backup with a ftps repo with a daily schedule. When it starts the second backup or any next backup it shows the following error when keyhelp runs the cleanup:
Failed to prune repository: {"message_type":"exit_error","code":11,"message":"unable to create lock in backend: repository is already locked by PID 3066733 on host.server.com by root (UID 0, GID 0)\nlock was created at 2026-01-04 15:46:57 (11m39.436724347s ago)\nstorage ID 08af0c1b\nthe `unlock` command can be used to remove stale locks"}
Please note this will happen only when running the second time, we can use the unlock option, but I tried this many times, it always has a stalled lock file. So I need to use this every backup, which makes the schedule backup unusable.
Expected result
Run multiple backups with cleanup with no lock issue
Actual result
As above, when the second or next backup run the cleanup will fail.
Steps to reproduce
Run the backup schedule minimal 2 times.
Additional information
I checked the log but I cannot find any more restic error log, I am searching why the lock file is not removed. The repo setip is a ftps server, and I also tried a custom rclone config with:
type = ftp
host = host.server.com
user = username
pass = password
explicit_tls = true
no_check_certificate = true
And also with max connection set to 1 but still the same error. I tried 2 different machines but they all do the same. It looks like the problem can be in the ftps repo, but I do want to find the issue to solve.
Re: issues with backup and lock
Can you switch to SFTP just for testing purpose? FTPS sometimes seams a bit fragile, if the remote server is using an outdated FTP Server version etc.
Also you may want to reduce the amount of concurrent connections below "Advanced settings" for the FTP connection.
But the minimum is two connections.
Otherwise pruning will not work.
RikkerdNL
Re: issues with backup and lock  [SOLVED]
Post by RikkerdNL »
Thank you for the help. I changed the connection without any solution. I switched to sftp and this has no lock issues any longer. The issue is strange because I also use restic with my own bash script this does a backup and a clean action, without issues on the ftps host.
So for now it works via sftp.
