Gültige, voll qualifizierten Domainnamen?  [GELÖST]
Re: Gültige, voll qualifizierten Domainnamen?
Rasgemuet wrote: Thu 4. Aug 2022, 16:23 was besseres habe ich gerade nicht gefunden
Schau mal in
/var/log/mail.info
Rasgemuet
Post by Rasgemuet »
24unix wrote: Thu 4. Aug 2022, 16:32
Schau mal in
/var/log/mail.info
hier mal die mail.log, gleicher inhalt wie mail.info
mail.log
(4.86 KiB) Downloaded 389 times
MLan
Post by MLan »
......... status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Dein Amavis läuft nicht
systemctl status amavis.service
Rasgemuet
Post by Rasgemuet »
MLan wrote: Thu 4. Aug 2022, 17:04
Wie kann ich den Service starten
MLan
Post by MLan »
Rasgemuet wrote: Thu 4. Aug 2022, 17:08
hmm das weiss ich jetzt auch nicht, mal warten ob sich jemand anders mit viel Ahnung meldet.
Rasgemuet
Post by Rasgemuet »
MLan wrote: Thu 4. Aug 2022, 17:10
habe eine Störung wohl
● amavis.service - Interface between MTA and virus scanner/content filters
Loaded: loaded (/lib/systemd/system/amavis.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2022-08-04 17:10:20 CEST; 4s ago
Docs: http://www.ijs.si/software/amavisd/#doc
Process: 22980 ExecStartPre=/usr/bin/find /var/lib/amavis -maxdepth 1 -name amavis-* -type d -exec rm -rf {} ; (code=exited, status=0/SUCCESS)
Process: 22981 ExecStartPre=/usr/bin/find /var/lib/amavis/tmp -maxdepth 1 -name amavis-* -type d -exec rm -rf {} ; (code=exited, status=0/SUCCESS)
Process: 22982 ExecStart=/usr/sbin/amavisd-new foreground (code=exited, status=255/EXCEPTION)
Main PID: 22982 (code=exited, status=255/EXCEPTION)
CPU: 482ms
Aug 04 17:10:20 {HOST} systemd[1]: amavis.service: Scheduled restart job, restart counter is at 5.
Aug 04 17:10:20 {HOST} systemd[1]: Stopped Interface between MTA and virus scanner/content filters.
Aug 04 17:10:20 {HOST} systemd[1]: amavis.service: Start request repeated too quickly.
Aug 04 17:10:20 {HOST} systemd[1]: amavis.service: Failed with result 'exit-code'.
Aug 04 17:10:20 {HOST} systemd[1]: Failed to start Interface between MTA and virus scanner/content filters.
Was passiert, wenn
ausführst?
Rasgemuet
Post by Rasgemuet »
24unix wrote: Thu 4. Aug 2022, 17:15 Was passiert, wenn
ausführst?
The value of variable $myhostname is "HOST", but should have been
a fully qualified domain name; perhaps uname(3) did not provide such.
You must explicitly assign a FQDN of this host to variable $myhostname
in /etc/amavis/conf.d/05-node_id, or fix what uname(3) provides as a host's
network name!
MLan
Post by MLan »
cat /etc/hostname
Rasgemuet
Post by Rasgemuet »
MLan wrote: Thu 4. Aug 2022, 17:18
cat /etc/hostname
der stimmt, da kommt der richtige
Und was sagt:
grep -i myhostname /etc/amavis/conf.d/*
Edit: befehl angepasst, war eine alte Version.
So sieht es bei mir aus:
/etc/amavis/conf.d/05-node_id:# $myhostname is used by amavisd-new for node identification, and it is
/etc/amavis/conf.d/05-node_id:chomp($myhostname = `hostname --fqdn`);
/etc/amavis/conf.d/05-node_id:# To manually set $myhostname, edit the following line with the correct Fully
/etc/amavis/conf.d/05-node_id:#$myhostname = "mail.example.com";
Also, die Rückgabe von hostname --fqdn muss passen.
Rasgemuet
Post by Rasgemuet »
24unix wrote: Thu 4. Aug 2022, 17:22 Und was sagt:
grep -i myhostname /etc/amavisd.conf
grep: /etc/amavisd.conf: Datei oder Verzeichnis nicht gefunden
MLan
Post by MLan »
uname -n
Rasgemuet wrote: Thu 4. Aug 2022, 17:23
Ich habe oben noch mal editiert, amavis hat nun ein eigenes Verzeichnis.
Rasgemuet
Post by Rasgemuet »
habe den amavis.service zum laufen bekommen, erst systemctl reset-failed amavis.service und dann systemctl start amavis.service
Email gehen aber immer noch nicht raus
hier nochmal die Log vom letzten Versuch
mail.log
(4.48 KiB) Downloaded 311 times
