IMUNIFYAV
- BasHeijermans
- KeyHelp Translator
Re: IMUNIFYAV
Because if you do, then swapping is not allowed inside the VPS.
Re: IMUNIFYAV
1. Create domain for the Webpanel of Imunify
2. Enable PHP function proc_open (disabled by default)
3. Create file /etc/sysconfig/imunify360/integration.conf
4. Make configuration in integration.conf
Example:
[paths]
ui_path = /home/users/keyhelp-user/www
ui_path_owner = keyhelp-user:keyhelp-user
[pam]
service_name = system-auth
wget https://repo.imunify360.cloudlinux.com/defence360/imav-deploy.sh -O imav-deploy.sh
bash imav-deploy.sh
Re: IMUNIFYAV
It was openvz before but now it is kvmliteBasHeijermans wrote: ↑Thu 16. Feb 2023, 11:59 Are you using OpenVZ type VPS?
- Attachments
- specss2.PNG (11.64 KiB) Viewed 3438 times
Re: IMUNIFYAV
Hi florian!Florian wrote: ↑Thu 16. Feb 2023, 13:49 Install of ImunifyAV on KeyHelp
Example:
5.Code: Select all
[paths] ui_path = /home/users/keyhelp-user/www ui_path_owner = keyhelp-user:keyhelp-user [pam] service_name = system-auth6. After the installation you should reach the Webpanel under the domain created in step 1 and login as rootCode: Select all
wget https://repo.imunify360.cloudlinux.com/defence360/imav-deploy.sh -O imav-deploy.sh bash imav-deploy.sh
Can you make the owner of imunifyav root-root and not a keyhelp-user? So it will scan /home/users/ and not just /home/users/keyhelp-user ?
Their page says debian 10 only. Will this run on debian 11?
How can you uninstall this later? Just delete the directory? Thanks!
Re: IMUNIFYAV
I dont think it scans within archives and it detected this. Is this part of keyhelp?
/home/keyhelp/www/adminer/adminer/adminer.php
Re: IMUNIFYAV
the user is only for the webpanel.
Just have a look into the manual for further information:
https://docs.imunifyav.com/imunifyav/#h ... -imunifyav
Adminer is an alternative for PHPmyAdmin and installed with Keyhelp.
