Debian 12 & keyhelp  [SOLVED]
Re: Debian 12 & keyhelp
Kann ich heute und am Wochenende ganz normal Debian 12 als Grundlage nehmen?
Oder doch lieber noch 11?
Can you explain what you mean with 'Grundlage'?
I will turn off the update of 23.2 today at around 16:00 o'clock until next Wednesday, when i activate it again.
So you wont be able to install Debian 12 with KeyHelp until Wednesday.
Sorry!
i forgot we are in the english section.
I prefer Debian over Ubuntu and i have to install two servers this weekend.
I dont care if i use Debian11 or 12.
i just wanted to avoid any trouble while installing.
So what is the preferred Debian Version regarding the KeyHelp installer?
Alexander wrote: Fri 29. Sep 2023, 12:22 Can you explain what you mean with 'Grundlage'?
THX
linux auswahl.png (22.91 KiB) Viewed 22082 times
Thank you anyway for your quick answer.
Have a nice weekend!
ADG1
Post by ADG1 »
Have a look here: System Status -> Rspamd Web Interface
ADG1
Post by ADG1 »
Before I start guessing, can you send me the login data to your server, so I can have a look?
ADG1
Post by ADG1 »
Hi, pn for you
Thanks for reporting. I have found the issue and fixed it on your server.
This is caused by a bug, when letting KeyHelp rewrite its /etc/apache2/keyhelp/keyhelp.conf file (e.g. via keyhelp-toolbox)
It will pick the wrong template for this configuration file.
I will create a proper forum post in a couple of minutes, a fix and update the release files.
EDIT: The post can be found here: viewtopic.php?t=12687
ADG1
Post by ADG1 »
Thank you
jcolideles
Post by jcolideles »
Alexander wrote: Fri 29. Sep 2023, 11:31 Have a look here: System Status -> Rspamd Web Interface
ahh that's where it is thank you. it's working.
amarc
Post by amarc »
@Alexander what would be proper location to do own rspamd customisation ? I see in local.d/* it says "do not edit". override.d/* I guess ?
Tnx
override.d/ would be the appropriate directory.
amarc
Post by amarc »
Just had time to again test install and play some more with Debian 12 version.
Too bad you missed how extensible Rspamd is @Alexander . For example I see you completely removed "Spam filter Black/White list" under Settings>Configuration>Email server.
That could easily be done with Multimap module but with nice UI to maintain this. I tend not to do anything via Rspamd Web interface, specially do not want to give clients to mess with it.
Example config could look like:
BLACKLIST_SENDER_DOMAIN {
      type = "from";
      filter = "email:domain";
      map = "$LOCAL_CONFDIR/local.d/domain_bl.map.inc";
      action = "reject";
or similar for "whitelist" but not with action = "accept" but maybe just lowering score:
WHITELIST_SENDER_DOMAIN {
      type = "from";
      map = "$LOCAL_CONFDIR/local.d/domain_wl.map.inc";
      score = -15.0
