erro upload file  [SOLVED]
obaviet
erro upload file
Post by obaviet »
i setup this:
php_admin_value[memory_limit] = 128M
php_admin_value[post_max_size] = 7000M
php_admin_value[upload_max_filesize] = 6400M
php_admin_value[max_execution_time] = 1800
php_admin_value[max_input_vars] = 2000
and upload a file 600mb but error
Re: erro upload file
Where have you changed the values?
obaviet
Post by obaviet »
Alexander wrote: Sat 17. Oct 2020, 15:53 Where have you changed the values?
keyhelp.conf
Have you restarted the PHP-FPM daemon?
service php<x.x>-fpm restart
Replace <x.x> with your PHP Version of your operating system.
By the way, you need to increase your memory_limit as well.
obaviet
Post by obaviet »
Alexander wrote: Sat 17. Oct 2020, 16:06 Have you restarted the PHP-FPM daemon?
Of course I resart it
george
Re: erro upload file  [SOLVED]
Post by george »
hi Obaviet,
your memory limit must be higher than the others:
php_admin_value[memory_limit] = 128M <== TOO LOW
If you have the memory, try:
php_admin_value[memory_limit] = 7200M
obaviet
Post by obaviet »
george wrote: Sat 17. Oct 2020, 16:56 hi Obaviet,
I tried again but it doesn't work. I setup:
php_admin_value[memory_limit] = 1000M
php_admin_value[post_max_size] = 900M
php_admin_value[upload_max_filesize] = 800M
Phpmyadmin never worked for me with huge uploads.
Better try bigdump.
https://www.ozerov.de/bigdump/
george
Post by george »
There must also be adequate time to upload:
max_execution_time
The limiting factors here are SIZE and TIME.
Note, that if phpmyadmin itself has different values for these (or any other php configs), they need to be adjusted too.
obaviet
Post by obaviet »
george wrote: Sun 18. Oct 2020, 01:49 There must also be adequate time to upload:
max_execution_time
Tried again but doesn't work
obaviet
Post by obaviet »
I change php_admin_value[max_input_vars] = 3000
but it does'nt work
Please help me
george
Post by george »
For upload database, try by command line:
mysql -u root -p db_name < db_name.sql
obaviet
Post by obaviet »
george wrote: Mon 19. Oct 2020, 08:26 For upload database, try by command line:
All the errors I have encountered here are not resolved. It's a headache with it. Don't know if you got the same error as me?
george
Post by george »
No, I have no such errors.
If you are determined to fix this, you will need to do what is required, as we all do.
Your posts include very little that others can use to help you. If you want help to resolve this, post some useful information, mainly the content of your LOGS, when the error occurs. Checking logs for errors, is basic linux administration practice.
Forum participants appreciate posts that show the user has actually done the work to fix it - searches, manuals, forums, wikis, etc - and then present their findings. Then responses will have much more value, usually leading to a real solution. This will be based on the quality of the diagnostic output provided.
I only ever post a question on a forum, AFTER I have exhausted all other available options, and done the work required. Then I can post all the "clues" for the puzzle to be solved.
Did you try bigdump?
