KeyHelp 20.3 | Service/port monitoring does not work? -> Solution
Problem:
On the admin dashboard, the following things do not work:
- service/port monitoring shows only a loading animation
- pending updates are not displayed
- the content of the notes box cannot be changed
Occurs only when:
- the white label setting "Hide KeyHelp news on the admin dashboard page". is enabled
Solution:
EDIT: Problem is fixed in 20.3.1 -> Please update to KeyHelp 20.3.1 to solve the problem
hexacube
Re: KeyHelp 20.3 | Service/port monitoring does not work? -> Solution
Post by hexacube »
That worked perfectly. Thank You.
