Auto logout when uploading files  [SOLVED]
martins
Post by martins »
Hello there,,
I tried to upload a ZIP file with the size of 80M via File Manager, but failed and the panel keeps logged out automatically. For the files below 70M are work fine.
I also tried to setup PHP configuration on the user like below:
max_execution_time=300
post_max_size=100
upload_max_filesize=100
but the change didn't take effect on upload message board, which is still in default
 'Maximum file size: 64.00 MB / Total: 70.00 MB'
Is there any other way to change the PHP preferences to meet the clients need? Or am I miss something?
Thank You very much!
*sorry for my English
Re: Auto logout when uploading files  [SOLVED]
One need to update PHP settings of the "keyhelp" user (who is running the KeyHelp UI), which are located here:
/etc/php/<PHP_VERSION>/fpm/pool.d/keyhelp.conf/
A reload of the PHP-FPM daemon is required afterwards.
