Ubuntu 20.04 Come with No Network Directory
Tony20
Post by Tony20 »
Ubuntu 20.04 come with not network directory /etc/network/ Ubuntu 20.04 come with Netplan /etc/netplan/
When you run the KeyHelp installation it create the network directory., but the installed is with one error.
Warning: file_put_contents(/etc/network/if-pre-up.d/keyhelp_load_rules): failed to open stream: No such file or directory in /home/keyhelp/www/keyhelp/core/pending/File.php on line 341
The fix, create the /etc/network/if-pre-up.d/ and run installation again, Now there is a "Quote Error" when you run installation again.
I hope developer check this out and fix it for the next KeyHelp version.
I am trying it on Dedicate Server.
Ubuntu 20.04 minimal iso
Re: Ubuntu 20.04 Come with No Network Directory
it is a know issue with the current version and will be taken care of with the next release. Thanks anyways ;).
