Invalid MX Records - How to Configure
LastSavingGrace
Post by LastSavingGrace »
Hi Alexander ,
I use MXRoute for my email hosting, so I have to add their MX records. Let's say my domain is 'example.com'. I have added them as per the docs:
* 86400 MX 10 blizzard.mxrouting.net
* 86400 MX 20 blizzard-relay.mxrouting.net
It works, but when viewing the DNS I see this:
10   blizzard.mxrouting.net.example.com   No A Record (no glue either)
20   blizzard-relay.mxrouting.net.example.com   No A Record (no glue either)
My domain is attached to the MX record. This is invalid. What I see on my other domains is:
20   blizzard-relay.mxrouting.net   12.34.56.78 (no glue)
10   blizzard.mxrouting.net   12.34.56.78 (no glue)
Where 12.34.56.78 is obviously my IP address. Can I make a change to the MX records with Keyhelp to achieve this? Or is there another way, maybe via command line?
Thank you.
Re: Invalid MX Records - How to Configure
your simply forgot the closing dot:
Correct would be:
* 86400 MX 10 blizzard.mxrouting.net.
* 86400 MX 20 blizzard-relay.mxrouting.net.
If you forget the closing dot the name of the zone is added to the entry
LastSavingGrace
Florian, thank you very much. That fixed it. Appreciate the help.
