How to disable auto update of the panel  [SOLVED]
Amadex
Post by Amadex »
how to disable auto update of the panel and other auto update things in case that the dedicated server goes down and the VMs with it? Server reboot or network outage while auto update could make many problems.
I want to update the things by cli.
Thanks.
Re: How to disable auto update of the panel
you can disable various update tasks via "Maintenance Intervals" in administrator's navigation menu.
Read the descriptions on this page to disable your desired tasks.
Amadex
Post by Amadex »
Thanks for you help, also thanks for this awesome piece of software. 8-)
Btw. I guess the manual update goes with: apt-get update && apt-get upgrade for everything?
Re: How to disable auto update of the panel  [SOLVED]
Great that you like KeyHelp ;).
You can perform manual KeyHelp updates by calling the command:
keyhelp-toolbox
Then navigate to "6) Start maintenance tasks" -> " 3) Update control panel (panel-update)"
Amadex
Post by Amadex »
Alexander wrote: Wed 16. Dec 2020, 08:18 Great that you like KeyHelp ;).
keyhelp-toolbox
One more question. I'm using FileZilla, when I upload .htaccess files they are not shown (dotted files). But in file manager inside panel I can see them.
Is that normal?
Yes, you have to enable "show hidden files" in your Filezille.
