Change mysqladmin password?  [SOLVED]
LastSavingGrace
Post by LastSavingGrace »
Is it possible to change the mysqladmin password? I tried:
UPDATE mysql.user SET authentication_string = PASSWORD('newpass')
WHERE User = 'mysqladmin' AND Host = 'localhost';
FLUSH PRIVILEGES;
The affected rows was 1, but the login fails.
Thank you.
Re: Change mysqladmin password?  [SOLVED]
this is not the SQL how one would update the password.
Use this instead:
UPDATE `mysql`.`user` SET `Password` = PASSWORD('newpass') WHERE `User` = 'mysqladmin';
FLUSH PRIVILEGES;
LastSavingGrace
Perfect, thanks Alexander. Not sure where I got that other code from.
Merry Christmas.
