How much RAM, CPU and so on do you use?
Amadex
Post by Amadex »
Here is my setup, VPS KVM:
Shirobaka
Re: How much RAM, CPU and so on do you use?
Post by Shirobaka »
VPS KVM
Reez
Post by Reez »
Dedicated :)
Die letzten Worte eines Informatikers "Ich bleibe hier bis das Problem gelöst ist."
pandogulf
Post by pandogulf »
Thanks Amadex for this thread !
Nice setup !
@Shirobaka, that is a massive VPS 8-)
@Reez cool, you might need to hide the hostname/ip info through.
Mine : )
KVM VPS
dedicated server :)
Lou Zypher
Post by Lou Zypher »
Mal abgesehen davon: was läuft auf dem entsprechendem teil von dem der Screen ist?
Bei mir läuft meine eigene HP, zwei Onlineshops und ein Forum drauf.
martins
Post by martins »
Dedicated Server:
latifolia
Post by latifolia »
@latifolia
Which type of CPU do you use exactly?
Is it your private system or is it hosted?
Thanks Tobi for point it out again.
@latifolia, it seems that your CPU label is not showing correctly in the KeyHelp UI, is that correct or did you remove it just for the screenshot?
If you didn't remove it, would you please be so kind and post the result of the following command so I can fix the issue.
/proc/cpuinfo
latifolia
Post by latifolia »
@Tobi @ Alexander
Yes, they are not shown correctly. You see what I see.
Basically it is ARM instance (4 Cores/24GB mem) on Oracle Cloud.
turbopixel
Post by turbopixel »
Viele Grüße
turbopixel
Amadex
Post by Amadex »
turbopixel wrote: Wed 15. Dec 2021, 12:47 Image
Warum hast du kein SWAP? :shock:
