On 99% of servers the update runs smoothlyy, on the remaining 1% the job hangs and prevents the panel update from continuing to run.
I'm currently investigating the reason for this, respectively implementing precautions for KeyHelp 21.0 to work around the problem.
The solution:
1.) Get the process ID of the hanging job
cat /home/keyhelp/.lock/repo-update.lock2.) Kill the hanging process (instead of 12345 insert the corresponding process ID)
kill 12345=> Done
The panel update will now resume automatically and the message "The control panel is currently being updated." disappears.
