KeyHelp Themes
pandogulf
KeyHelp Themes
Post by pandogulf »
Greetings KH Community,
I tried looking for additional themes for the Panel. I managed to find one called minimal "currently broken" unfortunately.
https://github.com/iandk/keyhelp-theme :mrgreen:
Although the default theme looks exccellent but one would like to change every now and then.
Are there any themes available for KH ? a grid/icons theme would be nice or the default theme with ability to change skin color
I hope we see more designers in the community to add more themes for KeyHelp.
I would participate in designing a new theme, the problem is that I suck in designing website and stuff. But I'll give it a try anyway, so is there a template/guidelines for that :) ?
Have a good day.
Re: KeyHelp Themes
Buy the Pro-Version and get a dark mode for keyhelp.
Or use the whitelabel CSS and do whatever you want.
v3ng
Re: KeyHelp Themes
Post by v3ng »
I started designing this theme a few months ago but haven't had the time to maintain it unfortunately.
I might have a look at it again at some point
pandogulf
Re: KeyHelp Themes
Post by pandogulf »
That would be appreciated v3ng
Thanks
pandogulf
Re: KeyHelp Themes
Post by pandogulf »
Tobi wrote: Wed 3. Mar 2021, 06:37 Buy the Pro-Version and get a dark mode for keyhelp.
I have the pro version, and I believe the whitelabel CSS only changes the colors/looks and doesn't touch the overall layout.
It would be interesting to see a new theme/layout with Grid style (like DirectAdmin and Cpanel) in the future update ( not necessary this year)
Pretty sure there is a plan for additional themes or why would we see Themes under configuration if the plan to have one forever :)
Is there a way for us as community to help with designing new themes ? is there a template that we can use to do so..
pandogulf
Re: KeyHelp Themes/Dark Mode
Post by pandogulf »
Hello All,
I started playing with the additional CSS and I made a free Dark Mode for Standard KeyHelp panel users. I call it the poor-man DarkMode :lol:
Instructions: :mrgreen: :geek:
Settings>Configuration>White Label>(Edit)All Languages: Inside the Additional CSS box add this code...Then click SAVE and Enjoy
.title {
    color: white;
html {
    background-color: black;
#header {
    background-color: #141415;
#user-menu {
    background-color: #1e1c1c;
#header a {
    color: #e0dada;
.dropdown-item {
    color: #cacaca;
.card-header {
    background-color: #00000040;
.card {
    color: #fff;
.card-content {
    background-color: #7b7b7b21;
.table.is-striped tbody tr:not(.is-selected):nth-child(2n) {
    background-color: #f0efef;
.card-footer {
    background-color: #b6b6bc;
.breadcrumb li + li::before {
    color: #fffafa;
.breadcrumb li.is-disabled a {
    color: #fff;
.breadcrumb a {
    color: #6fbcff;
.breadcrumb a:hover {
    color: #ffb96f;
.card {
    color: #2b2b2b;
.has-text-grey-light {
    color: #8e8e8e !important;
.tabs a {
    color: #ffffffbf;
.tabs.is-boxed li.is-active a {
    background-color: #d7d7d7;
.tabs.is-boxed a:hover {
    background-color: #ddd;
    border-bottom-color: #0f0f0f;
.select select, .textarea, .input {
    background-color: #fbfbfb;
    border-color: #dbdbdb;
    color: #363636;
input[disabled], input[readonly], textarea[disabled], select[disabled] {
    color: #0d0d0d !important;
    border-color: #999797 !important;
    background-color: #c7c7d2 !important;
.has-text-grey {
    color: #555 !important;
.table {
    color: #000;
.file.is-link .file-cta {
    background-color: #285bac;
    border-color: transparent;
    color: #fff;
.button.is-link {
    color: #fff;
.button.is-danger {
    background-color: #a62c44;
    color: #fff;
body {
    color: #cecece;
    font-size: 1em;
    font-weight: 400;
    line-height: 1.5;
a {
    color: #0062ff;
Also you can make your OWN banner or upload the SVG img attached ZIP (extract the SVG file first then upload it at the Banner for internal area - in the same White label page).
DOWNLOAD HERE download/file.php?mode=view&id=1351
:D
method-draw-image(25).zip
(545 Bytes) Downloaded 750 times
Re: KeyHelp Themes
Of course it is appreciated to design an own theme. You can even do this, without using the White-Label feature and offer an own stand-alone theme, by creating a sub-folder within the /theme/ directory (have a look how Olli uses this feature with his theme viewtopic.php?f=16&t=8961)
The reason why I am writing and as a gentle notice for you: You have modified the KeyHelp logo. KeyHelp and all of its assigned logos / images are a registered trademark of the Keyweb AG company. You may not want to change the KeyHelp logo as you did with your preview images ;).
You can of course rename the control panel to the name you prefer, and also use an own logo.
pandogulf
Re: KeyHelp Themes
Post by pandogulf »
Alexander wrote: Sat 6. Mar 2021, 02:36 Of course it is appreciated to design an own theme. You can even do this, without using the White-Label feature and offer an own stand-alone theme, by creating a sub-folder within the /theme/ directory (have a look how Olli uses this feature with his theme viewtopic.php?f=16&t=8961)
Sorry, and above post updated :mrgreen:
Sure :), I'll create my own theme soon and for now this would be an easy guide for a quick dark mode through WL.
Thanks Alex.
hzm120
Re: KeyHelp Themes
Post by hzm120 »
if u need help let me know I can see I can make it more Ajax type -- or if u have a idea on what u want I can do my best to get it rolling
