migration to new server  [SOLVED]
curiousclumsy
Post by curiousclumsy »
I was wondering how can I migrate to a new server with the same hostname?
Here is what I think I should do
- Install keyhelp onto the new server
- Backup all databases - including mysql
- rsync /home/ to the new server
- Restore all databases
- Recreate all users
- Import crontab for each user
Is that the recommended way to do it?
Thanks
Re: migration to new server  [SOLVED]
or you use a Keyhelp Backup and restore it on the new server:
viewtopic.php?f=11&t=8892
curiousclumsy
Many thanks
