Unable to log in after following to remove DIR
fastuk
Post by fastuk »
hello,
I have a big problem, I have switched to test environment and back to live environment and have deleted the folder as directed here
The test environment generates invalid certificates, but is suitable for testing of settings and functionality.
After changing the environment, it may be necessary to remove the folder /etc/ssl/keyhelp/letsencrypt/.
I can no longer log in to the system. Any advice?
Many thanks,
Peter
MOD-EDIT: Formatting updated
Re: Unable to log in after following to remove DIR
What does this mean - What error message do you get?
Without the error message, we can only guess what is the cause.
Run the console command:
keyhelp-toolbox
Navigate to "Start maintenance tasks" -> "Maintenance of SSL/TLS certificates (ssl-maintenance)" and perform this task.
