How to use mysql 8.0?
akong77
Post by akong77 »
I amd new join keyhelp.I know keyhelp is use mariadb 10.3 on ubuntu 20.04 LTS.Could I change to mysql 8.0?
Re: How to use mysql 8.0?
even though MySQL is supported by KeyHelp, it is not recommended to switch to MySQL instead of MariaDB.
MySQL and MariaDB drift apart in terms of how they handle their internal databases. Support for upcoming MySQL versions cannot be guaranteed, MariaDB will always be supported by KeyHelp. Also, MySQL is not fully tested during KeyHelp rollout tests, while MariaDB is.
akong77
Post by akong77 »
So....
I understood.Thanks a lot.
