Debian 11 Bullseye Support  [SOLVED]
Victor
Post by Victor »
Hello everybody,
I know that Debian 11 has just been released a couple of days ago, but I must install some servers next week and depending of the KeyHelp support for Debian 11, I will either go with a Debian 10 and upgrade to 11 If an upgrade path will be supported by KeyHelp in the near future, or I will go straight to Ubuntu 20.04 if the support will arrive in more than 1-2 months.
So my question is, if anyone knows, if and when (aprox.) will KeyHelp support Debian 11 Bullseye (Either fresh install or 10->11 Upgrade Script)
Thank you!
This is an awesome panel! :D
Something something, dark side.
Re: Debian 11 Bullseye Support
of course there will be support fpr Debian 11 and our developer is already working on it. But at the moment I cannot predict a concrete realease date.
Victor
Post by Victor »
Understood, thank you for the information!
Re: Debian 11 Bullseye Support  [SOLVED]
Hello!
Next KeyHelp release with Debian 11 support will go live round about mid of September.
Victor
Post by Victor »
That is just perfect, I will go with Debian then. Thanks for the answer Alexander!
