Backup Download  [SOLVED]
Tony20
Backup Download
Post by Tony20 »
It will be nice to be enable to Download the Backup zip file like in CP.
Re: Backup Download  [SOLVED]
This is not applicable. The preferred way to transfer a Repository is to connecting to the storage location and transfer it via FTP / SFTP etc..., later you can zip them if you like.
Technically it is possible to download a local user backup via the KeyHelp file manager as .zip / .tar, but as a repository probably is multiple GB in size, it will not work creating those large files on the fly and offer them to download.
Also creating those files right after backup creation and offer them to download is also not applicable, as there could be repos with p.ex. 900GB in size. It would be a waste of disk space to hold a .zip + .tar for such large repos.
