I have vserver with server4you running KeyHelp 21.0 on Ubuntu 16.04.
Unfortunately s4you does not support OS upgrades on their Virtuozzo Vserver infrastructure (lame of them, but cheap)
The problem I'm having is that because of the old system, I cannot install other PHP versions from the KeyHelp Dashboard.
This is the error I'm getting in the PHP Interpreter tab in KeyHelp :
Available interpreters
Here you see all available PHP interpreters, which could be installed on your server.
An error occurred.
Oh no, our repository server is currently not available.
We are going to fix this problem ASAP!
If you are using a recently released operating system, this message is normal 1-2 weeks after release,
due to the PHP interpreters have to been build first.
(Curl: SSL certificate problem: certificate has expired (https://repo.keyhelp.de/get_php_packages.php?os=ubuntu_16.04))
From the error message it's obvious that it's a SSL problem, but I have no ideea where to get a valid cert and where to put it.
Thank you!
