Easy Fail2ban configuration on the panel [SOLVED]
Re: Easy Fail2ban configuration on the panel [SOLVED]
In the next version you will have an overview of all active jails and the IPs blocked by the jails. You can also search for IPs or remove them from the blocked list.
I would have liked to offer even more features with the first version of the Fail2Ban management, but during implementation and testing I made the experience that it has a high potential to break something at every corner. I decided to reduce the features and prepare some things in the background (during the update process) so that I can offer more features in the upcoming versions.
tl;dr There is a Fail2Ban management with the next version, but you will probably miss features. More features will come with further updates.
goldene-zeiten
goldene-zeiten
goldene-zeiten
If you want to know whats up next, take a look at: https://changelog.keyhelp.de/goldene-zeiten wrote: ↑Wed 7. Dec 2022, 12:46 Ok. Because it was written, that in newer versions there is a admin interface. But if not, it will maybe come later.
If there is nothing new, it is useless asking here.
Thank you for your cooperation.
