Hello again,
I tried to find this myself but had no luck. I am creating users without any www stuff (Keyhelp being used for email only) and I also create users with 0 subdomains. Not to mention subdomains make no sense for email.
I would like to make this option unchecked by default so I can also hide it with css via Whitelabel.
Can you point me where can I make this "unchecked" by default ?
To be more specific, this is under "Add domain" via user control panel
Thank you
Make checkbox defaults as 'unchecked' [SOLVED]
Re: Make checkbox defaults as 'unchecked' [SOLVED]
Well.. long weekend and I managed to figure it out with WhiteLabel "Additional Java Script" option with simple:
$('input[name=create_www_subdomain]').attr('checked', false);
