keyhelp behind NAT and multiple keyhelp servers
pbandurek
Post by pbandurek »
two queries
Is it possible to install keyhelp server behind nat using private ip and forward public address with my firewall (box - Forti - Sonic) ? where do I specify the public IP for example for the ftp for example?
Is it possible to integrate more than 1 server with keyhelp to share a domain base etc to facilitate the management of several servers?
thanks
Re: keyhelp behind NAT and multiple keyhelp servers
pbandurek wrote: Wed 26. Jan 2022, 15:08 two queries
Do you have a static or dynamic IP on you gateway?
Can you elaborate that a little bit?
mfg Micha
… oh wait, he does.
pbandurek
Post by pbandurek »
A large static public ip range 200.55... in front of my corporate firewall and keyhelp servers zone with private ip range 192.168...
ftp usually requires displaying your real masquerade ip some other daemon will require similar configuration.
all important port are forward in my firewall 20,21,22,25,80,110,443,993,995,3306,etc
scenarios to host 500-800 or 1500 domains requires more than 1 server and the administration of the data of each one does require a certain centrality or it will be an administrative problem
using a central database for all servers could be the solution but I don't know if the keyhelp architecture can offer a solution or is on the roadmap, that's why my question is that I am evaluating adopting keyhelp pro for the management of our datacenter
pbandurek wrote: Wed 26. Jan 2022, 17:25 A large static public ip range 200.55... in front of my corporate firewall and keyhelp servers zone with private ip range 192.168...
And you need FTP?
With SCP/SFTP the should be less trouble.
I doubt that Keyhelp can handle that for what I've learned so for about the software.
mfg Micha
… oh wait, he does.
pbandurek wrote: Wed 26. Jan 2022, 17:25 using a central database for all servers could be the solution but I don't know if the keyhelp architecture can offer a solution or is on the roadmap, that's why my question is that I am evaluating adopting keyhelp pro for the management of our datacenter
There is no such thing out of the box, but KeyHelp provides an API: https://api.keyhelp.de
With its help, you are able to create what you have in mind.
