How to change port 25  [SOLVED]
rogernet
Post by rogernet »
My vps blocks port 25 and I can't send emails, I receive normally. How do I change port 25 to another port that I can send emails to. Thanks.
KeyHelp 21.3
Ubuntu 20.04
Roundcube
Re: How to change port 25
for sending mails you can use port 587 that is active by default
rogernet
Post by rogernet »
Florian wrote: Mon 14. Feb 2022, 12:56 Hallo,
Thanks for the reply my friend. How do I leave only port 587 for sending emails?
Port 25 must always be open because mailservers communicate via this port.
rogernet
Re: How to change port 25  [SOLVED]
Post by rogernet »
Solved. Hetzner enabled port 25 and it is working now. Thanks.
