Recommend fix dovecot tls settings.  [SOLVED]
akong77
Post by akong77 »
My customer use iphone login keyhelp mail server will failed.The error log is:
TLS handshaking: SSL_accept() failed: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown
I search google it's recommend edit dovecot tls version.
/etc/dovecot/conf/ssl.conf
ssl_min_protocol = TLSv1.1
Please check it and edit it if it's need change.Thanks a lot.
space2place
Re: Recommend fix dovecot tls settings.  [SOLVED]
Post by space2place »
akong77 wrote: Mon 14. Mar 2022, 02:29 ssl_min_protocol = TLSv1.1
Take a a look in the settings of KeyHelp. There you can manage the TLS Ciphers.
akong77 wrote: Mon 14. Mar 2022, 02:29 Please check it and edit it if it's need change.Thanks a lot.
Please read this -> https://www.quora.com/Is-TLS-1-1-safe
