Access to Email with webmail and email client
diegoge
Post by diegoge »
Hi everyone.
I have two questions related to email access.
1. Can I have a secure https connection to the address webmail.<mydomain>?. I tried registering it as a subdomain but it didn't work.
2. To access from a mail client, what is the way to configure the Imap/pop with mail.<mydomain>? currently I only see the domain <mydomain> and the domain of the host
I appreciate your responses
Re: Access to Email with webmail and email client
diegoge wrote: Sun 24. Apr 2022, 19:51 Can I have a secure https connection to the address webmail.<mydomain>?
In example you can use a reverse proxy, take a look there ->
viewtopic.php?p=20441#p20441
diegoge wrote: Sun 24. Apr 2022, 19:51 To access from a mail client, what is the way to configure the Imap/pop with mail.<mydomain>?
Normally this is configured automatically by the client via the Autoconfig/Autodiscover information the server provides to the client.
Thanks to the new mail server SNI feature of the latest KeyHelp update, every domain which is protected by an TLS/SSL certificate and which is marked as can-be-used-for-email can be used.
So you can create the domains webmail.<mydomain>, imap.<mydomain>, etc.; equip them with a Let's Encrypt certificate and mark them as email domain
(this can be done via KeyHelp Admin Area -> Domains -> Select the webmail.<mydomain> for editing -> Tick the checkbox "Email domain").
After the setup, all of those domains can also be used as server name in your email client.
Note: These domains are not shown in the connection information window, to not clutter the view. Also the Autoconfig/Autodisover will for now always return the general server name as Server domain.
stephan-ipt
Post by stephan-ipt »
Hi Alexander
if i do KeyHelp Admin Area -> Domains -> Select the webmail.<mydomain> for editing -> Tick the checkbox "Email domain")
after when i go on https://webmail.mydomain.com i'n not go to roncube but default page website
in admin area i have also use
Keep the domain name
The domain name in the address bar remains unchanged.
Insecure access via http:// will be redirected to a secure https:// connection.
it's possible to have for each webmail.domaine.com a SSL for rondcube ?
actually i have ssl for myserver.com/webmail
thanks for help
stephan
It depends on what you have setup at your Domain provider. You need to check those settings there.
For now, can create a domain "webmail.<DOMAIN>" for each main domain, and protect it via SSL. Than redirect it to the webmail location.
You can also use the API for that, to automate things.
A automated solution (without any manual work) will at some point be implemented in KeyHelp.
stephan-ipt
thanks
my webmail.domain.com have IP server in A record
so no problem
if i configure redirection to myserver.com/webmail and don't use local repertorie
i have my https://webmail.domaine.com to https//:myserver.com/webmail
and i loose url https://webmail.domaine.com
i want to keep https://webmail.domaine.com for rondcube
it's possible ?
at the moment this is only possible if you create teh webmail subdomai and use mod_proxy:
viewtopic.php?p=38131#p38131
Do not forget to run:
a2enmod proxy_http
before using Proxy requests
