Is Ubuntu 22.04 supported ?  [SOLVED]
amarc
Post by amarc »
I know this question is pretty much RTFM but I could not found anything other than "LTS version of Ubuntu" is supported. So is latest 22.04 supporterd too ?
A.
Re: Is Ubuntu 22.04 supported ?
It will be supported with the next KeyHelp Release 22.1.
Currently there is no ETA for that.
gusarg81
Post by gusarg81 »
Hi, I have KeyHelp 22.1.1 over Ubuntu 20.04.
This means Ubuntu 22.04 is supported or not yet?
Thanks.
goldene-zeiten
Post by goldene-zeiten »
In Release Notes is written, that KeyHelp is ready for Ubuntu 22.04. But I can not find the upgrade script?
Goldene Zeiten Juweliere
BasHeijermans
Post by BasHeijermans »
I see no upgrade script either.
Did you try an test-installation to see if it works?
As you can always backup and restore, it's a bit more difficult but should work if a fresh install is supported.
Greetings Bas.
Re: Is Ubuntu 22.04 supported ?  [SOLVED]
a fresh install with Ubuntu 22 is possible.
The upgrade script will follow.
BasHeijermans
Greetings Bas.
