Keyhelp FollowSymLinks Update and 500 Internal Server Errors
LastSavingGrace
Post by LastSavingGrace »
This morning I woke up to find that all my websites were offline and showing 500 Internal Server Errors because of the recent Keyhelp update for the '.htaccess' files and the 'FollowSymLinks' update. I had an inbox full of monitoring servers reporting sites offline, not to mention emails from users complaining about the outage.
It would have been better to have sent out an advisory first before applying this automatically, so as to avoid issues. You might want to think about this next time.
Re: Keyhelp FollowSymLinks Update and 500 Internal Server Errors
What exactly were the issues on your system? - Wrong owner of symlinks?
info@eurhosting.net
Post by info@eurhosting.net »
Don't know if it was the same issue
But opencart hosted on keyhelp did not take the .htaccess modify and had to modify it by hand
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
chaiavi
Post by chaiavi »
I have the same problem
How can I fix it ?
Here is a link to a subfolder with a mybb system which shows error 500 and the logs show something about symlinks
https://unicorntales.org/kq4-perilsofro ... make/forum
Please help
check the owner and group of the used symbolic links. Often they belong to root. If so change user and group to the corresponding Keyhelp user with the help of chown -h
Also check the error.log of the Keyhelp User for information
sanxh
Post by sanxh »
Me too.
