Install Wordpress  [SOLVED]
Re: Install Wordpress
MyIDKaTePe wrote: Sat 25. Jun 2022, 18:09 https://i.imgur.com/OgMMWMB.png
my phpmyadmin from keyadmin login
That's totally valid.
A regular user doesn't have access to MariaDB/MySQL internal tables.
mfg Micha
… oh wait, he does.
MyIDKaTePe
Post by MyIDKaTePe »
24unix wrote: Sat 25. Jun 2022, 18:15
actually that phpmyadmin from keyadmin login
how to get root password ?
ok that the other question.. not related with this
now how to make the db connected without touching phpmyadmin ?
MyIDKaTePe wrote: Sat 25. Jun 2022, 18:20
Take a look at keyhelp_login_data_2022-* in the home folder of root.
The credential for your testdb work, so they should work for WP install.
mfg Micha
… oh wait, he does.
You need to enable the function "error_log".
Therefore you have to remove "error_log" from the list of disabled PHP functions.
Then the installation will succed.
MyIDKaTePe
24unix wrote: Sat 25. Jun 2022, 18:26
the fact is not :(
something was wrong with this panel.. cannot connect and give privilage
ShortSnow
Post by ShortSnow »
Please just confirm the way you create a new Database. Im am not sure you use Keyhelp for that.
Creating a database has nothing todo with phpMyAdmin.
Keyhelp as Admin:
  1. Create a User with minimum 1 Database in Resource & Permissions
  2. Switch to the User (click the username in the useradministration list)
  3. Create the Database under "Resourcen -> Database
  4. Set password for the database
  5. Use this credential for WP
CU Arne
MyIDKaTePe
ShortSnow wrote: Sun 26. Jun 2022, 03:46 Please just confirm the way you create a new Database. Im am not sure you use Keyhelp for that.
Keyhelp as Admin:
CU Arne
all i do just like that...
i use manual installation wordpress since 2010
even now sometimes i do that
if admin want to test my keyhelp panel
i will give the credential... so they know the problem ....
MyIDKaTePe
MyIDKaTePe
nevermind.. i destroy the vps now...
i think this control panel is not suitable for my infrastructur
even i think this panel light enough
i dont care about the opensource or not :D i just care the light and system,.
maybe if the wordpress problem and IP behind NAT solved by panel...
i will back here
BasHeijermans
Post by BasHeijermans »
I doubt the panel is the problem. :lol:
I installed several software under it and it works without problems.
Greetings Bas.
mzperx25
Post by mzperx25 »
Hello!
I also have this error.
1, I create an unlimited user
2. I enter the user interface
3, I create a database
The created database does not have the appropriate permissions.
What could be the reason for this?
You can't go wrong with it too much, some other setting can have an influence on it.
Thanks for the help
Screenshots: https://imgur.com/a/TZMnWL5
After you created the database in KeyHelp, you log in via phpmyadmin and instantly get the "No Privileges"?
You do not see the phpmyadmin Dashboard? Have you clicked anywhere?
Are you logged in with an other account and try to access the tables of an other database user? - phpmyadmin only allows one user session at a time.
Please send me KeyHelp login credentials via PM, as I can not reproduce this.
mzperx25
Post by mzperx25 »
Hi Alexander!
I sent the data.
Thanks for the help.
I can see the phpmyadmin interface and the menu items. But, I don't have permission to create tables. And I'm logged in to a good interface.
mzperx25 wrote: Fri 14. Oct 2022, 12:18 Hi Alexander!
I sent the data.
You should create the tables in Keyhelp, not PhpMyAdmin.
mfg Micha
… oh wait, he does.
Re: Install Wordpress  [SOLVED]
The databases are fine, but it is an incompatibility with WordPress and PHP 8.1 / 8.0.
(WordPress labels the support for PHP 8.0 and 8.1 as BETA itself: https://make.wordpress.org/core/handboo ... -versions/)
The installer failed and does not log any error message - i am currently digging through the WordPress code to find the exact reason.
(I get in touch with you mzperx25 in a second).
For everyone stumbling upon this:
As long as Wordpress does not fix this compatibility error with the latest PHP version 8.1, it is advisable to either run WordPress on p.ex PHP 7.4.
At least perform the install on PHP 7.4 and later potentially switch to 8.1 / 8.0.
