Add the subdomains  [SOLVED]
alamis
Add the subdomains
Post by alamis »
I don’t understand how I correctly add and install CMS?
Re: Add the subdomains
domains -> add domain
There you can choose to create a domain or subdomain
alamis
Post by alamis »
Florian wrote: Thu 13. Oct 2022, 13:51 Hallo,
Off course I did it but after that in which dirictotyn must put files?
Re: Add the subdomains  [SOLVED]
into the folder you configured when you created the subdomain. The default folder is the www-folder of the corresponding Keyhelp user. But of course you can configure a special subdirectory for the subdomain. Simply click on the pencil behind the subdomain.
alamis
Post by alamis »
Florian wrote: Thu 13. Oct 2022, 14:52 Hallo,
yes?
https://disk.yandex.ru/i/M4-NKDODHx24kw
yes!
