automatic restart  [SOLVED]
PuntonetSvb
automatic restart
Post by PuntonetSvb »
I want to make my server restart every day at 2 in the morning, using scheduled tasks, it asks me for a command, I put reboot, sudo reboot, and it gives me an error, what command could I use?
Re: automatic restart
You are not using Windows.
Why do you want to restart so often?
Re: automatic restart  [SOLVED]
The correct syntax is
/sbin/reboot
alamis
Post by alamis »
Tobi wrote: Thu 13. Oct 2022, 19:50 The correct syntax is
/sbin/reboot
And why sbin?
alamis wrote: Mon 31. Oct 2022, 19:34
/sbin/reboot
And why sbin?
# which reboot
/usr/sbin/reboot
And as of usermerge it's also available as /sbin/reboot
alamis wrote: Mon 31. Oct 2022, 19:34 And why sbin?
because it works 😂
BasHeijermans
Post by BasHeijermans »
PuntonetSvb wrote: Thu 13. Oct 2022, 19:20 I want to make my server restart every day at 2 in the morning, using scheduled tasks, it asks me for a command, I put reboot, sudo reboot, and it gives me an error, what command could I use?
Why?
We Linux users are proud to show our uptimes, the longer the better.
We never reboot unless is absolutly needed, something like this is our goal:
16:06:35 up 83 days,  2:57,  1 user,  load average: 1,58, 1,70, 1,72
And even that is short compared to a lot of others :lol:
Greetings Bas.
