Php Interpreters Install Failed
tarmanachels
Post by tarmanachels »
Hello anyone can you help me to solve this problem ?
sh: 1: /opt/keyhelp/php/8.1/bin/php: Exec format error
sh: 1: /opt/keyhelp/php/8.0/bin/php: Exec format error
sh: 1: /opt/keyhelp/php/7.4/bin/php: Exec format error
Waiting for your answer... Thank you
I'm Using Ubuntu 22.04 With aarch64/Arm64
Re: Php Interpreters Install Failed
The additional PHP versions are not (yet) compiled for your CPU. With ARM64 you can only use the native OS PHP version.
tarmanachels
Can I install manually ? Because my web project need php 7.4 when using native php "This page isn’t working is currently unable to handle this request.
HTTP ERROR 500"
Thank you
No, unfortunately not. If you change the PHP version of the operating system manually, KeyHelp will no longer work.
KeyHelp relies on the PHP Version of the operating system.
