Mail is missing from the server  [SOLVED]
alamis
Post by alamis »
I using Debian 11.
Log by CAT utility https://disk.yandex.ru/i/DABvyezYtBf1gw
My hoster unblocked 25 port, or needed another port ?
Re: Mail is missing from the server
you need an existing mailbox on your server.
The mailbox you sent the mail to does not exist as you can see in your log
alamis
Post by alamis »
Florian wrote: Thu 20. Oct 2022, 15:02 Hallo,
sorry, how add mailbox ?
alamis
Post by alamis »
you do not understand, I do not want to raise the mail server. The server is public. only here the sites do not send letters and the panel too. here is the address ask@ru7lan.ru
Re: Mail is missing from the server  [SOLVED]
How are we supposed to know something like that with your extensive descriptions?
When you are using external mail services for a domain that exists in Keyhelp you have to disable the mail services for this domain (pencil symbol behind teh domain), otherwise the sever will always try to send the mail locally.
alamis
Post by alamis »
Florian wrote: Tue 25. Oct 2022, 17:24 Hallo,
It’s work fine for the domains, but when I added Client Account this email went to the Spam
alamis
Post by alamis »
Thanks ☺️
