I get this error every day
PuntonetSvb
Hola DebianServer!
Su proceso de copia de seguridad se canceló, debido a un error!
Servidor: server.puntonetinformatica.es
Tipo de copia de seguridad: Server backup
Mensaje de error: upload_to_remote_failed
Saludos,
su equipo de soporte
Este mensaje se generó automáticamente.
Por favor, no responda a este correo electrónico
Re: I get this error every day
it writes "Server backup" - That means, it is the backup, you can administer via the administrator area of KeyHelp.
Otherwise it would say "Client backup" and would inform about the corresponding username.
PuntonetSvb
So either go to the "KeyHelp Admin Area -> Backup"
Now you should see the "Select backup management" - Page -> Select the "Alternate backup management".
In case you do not see this selection page anymore, first go to "KeyHelp Admin Area -> Configuration -> Backup" and tick the checkbox "Show alternative backup management"
