need some help. newbie to keyhelp
velton
Post by velton »
Hi All.
velton here. i just got install keyhelp but found that database was larger than max upload. and localhost was not working as well as ip.
may i know what is the database host ? im newbie in this all. sorry for stupid question..
:oops:
Re: need some help. newbie to keyhelp
Hello
it would be better to import large databases via the console. So connect to the server via SSH and import the database there. Large databases (and small ones too) usually take some time to import completely as well. If you do this via the browser, you may run into a timeout. Via the console you have no problems with the size of the database and the duration of the import.
localhost and 127.0.0.1 should both work. Just double check your login credentials for the database.
