PEAR and PECL is missing from PHP Interpreter 8.1  [SOLVED]
miklosandras
Post by miklosandras »
(Problems not related to KeyHelp belong in the Offtopic forum)
I think so.
Debian 11
22.2 (Build 2838)
PHP Interpreter: From php version 8.1 pear and pecl is missing
Expected result
pear and pecl should be available to install other modules like dbase as in PHP Interpreter version 7.1
root@keyhelp:/opt/keyhelp/php/7.1/bin# ls -l
total 131056
-rwxr-xr-x 1 root root      867 Nov 29 09:47 pear
-rwxr-xr-x 1 root root      888 Nov 29 09:47 peardev
-rwxr-xr-x 1 root root      801 Nov 29 09:47 pecl
lrwxrwxrwx 1 root root        9 Nov 29 09:47 phar -> phar.phar
-rwxr-xr-x 1 root root    14827 Nov 29 09:47 phar.phar
-rwxr-xr-x 1 root root 44473224 Nov 29 09:47 php
-rwxr-xr-x 1 root root 44228232 Nov 29 09:47 php-cgi
-rwxr-xr-x 1 root root     3113 Nov 29 09:47 php-config
-rwxr-xr-x 1 root root 45456432 Nov 29 09:47 phpdbg
-rwxr-xr-x 1 root root     4568 Nov 29 09:47 phpize
Actual result
root@keyhelp:/opt/keyhelp/php/8.1/bin# ls -l
total 154284
lrwxrwxrwx 1 root root        9 Nov 30 13:23 phar -> phar.phar
-rwxr-xr-x 1 root root    15257 Nov 30 13:23 phar.phar
-rwxr-xr-x 1 root root 51768720 Nov 30 13:23 php
-rwxr-xr-x 1 root root 51616976 Nov 30 13:23 php-cgi
-rwxr-xr-x 1 root root     3386 Nov 30 13:23 php-config
-rwxr-xr-x 1 root root 54567832 Nov 30 13:23 phpdbg
-rwxr-xr-x 1 root root     4565 Nov 30 13:23 phpize
Steps to reproduce
Installed and Uninstalled the version 8.1 with the same results
Additional information
Re: PEAR and PECL is missing from PHP Interpreter 8.1  [SOLVED]
PEAR / PECL has been disabled by default by the PHP developers for PHP 7.4 and above.
I have adopted this change for the PHP interpreters I compile for KeyHelp.
This is a feature request instead of a bug report.
But you may want to use composer instead.
miklosandras
Dear Alexander, Thanks for the reply. Then I will findout the way to using composer or install pear/pecl manually. Thank you.
