Apache stop/start from gui  [SOLVED]
miklosandras
Post by miklosandras »
Is there a possibility to stop/start Apache and PHP-FPM from gui?
Is there a settings to enable it to use?
Thank you in advance
Re: Apache stop/start from gui  [SOLVED]
Hello miklosandras,
this is impossible because without the Apache und PHP the GUI would not run.
But restart would be possible, for those afraid of the CLI :-)
BasHeijermans
Post by BasHeijermans »
Why would you even want to do it?
Because if the keyhelp-panel is still working fine, your problem is not with Apache and PHP, else KeyHelp would fail too. :D
Greetings Bas.
