How to redirect subdomain to server local port?  [SOLVED]
Natig
Post by Natig »
I installed traccar on GPS server from https://www.traccar.org/install-digitalocean/
how to setup subdomain config to make it work properly
I need to redirect the subdomain like this
https://gps.zaka.biz -> http://server_ip:portnumber/login
Re: How to redirect subdomain to server local port?
you must use mod_proxy.
Enable proxy_http module in the Apache Webserver and set the required proxy rules in the tab "apache settings" (use the pencil symbol behind the domain/subdomain name)
e.g.
 <IfModule mod_proxy.c>
</IfModule>
Alias /.well-known/acme-challenge /home/keyhelp/www/.well-known/acme-challenge
ProxyPass / http://127.0.0.1:Portnumber/
ProxyPassReverse / http://127.0.0.1:Portnumber/
Ther first lines make sure that you can use Let's Encrypt on a domain that uses mod_proxy
Natig
Post by Natig »
Thanks a lot, everything worked great.
