IP address changing  [SOLVED]
Drewpy
IP address changing
Post by Drewpy »
My provider needs to change its IP range
Do I just change the IP in the OS?
What do I have to do in KeyHelp (22.2), other than update the DNS records?
Thanks in advance
Re: IP address changing  [SOLVED]
It should be sufficient to update the values in "Configuration -> System -> IP Addresses".
If you have custom DNS settings, you have to update these modified DNS settings manually via "Domains -> DNS Zone Editor".
Drewpy
Post by Drewpy »
Hi Alexander,
I forgot to thank you for the answer, everything went well for the IP change
