PHP Extension
veszvs
PHP Extension
Post by veszvs »
Hello everybody, I'm new to the forum.
I've been using KeyHelp for weeks now, great panel, really nice.
But I have problems.
I need to enable and disable extensions of PHP versions.
Many of my scripts don't work properly.
Thank you.
christian.john
Re: PHP Extension
Post by christian.john »
Hallo and welcome,
perhaps you can tell us something about your scripts or even tell us something about the extensions you need.
Have you seen the configuration part where you can activate or disable php-functions?
Chris
Re: PHP Extension
PHP module for the system PHP version can be installed easily by apt
PHP modules for the additional Keyhelp PHP version have to be compiled or installed via PECL.
e.g. compiling of redis extension for PHP 7.4:
wget https://pecl.php.net/get/redis-5.1.1.tgz
tar xzf redis-5.1.1.tgz
cd redis-5.1.1/
/opt/keyhelp/php/7.4/bin/phpize (install autoconf if necessary)
./configure --with-php-config=/opt/keyhelp/php/7.4/bin/php-config
make
make install
echo "extension=redis.so" > /opt/keyhelp/php/7.4/etc/conf.d/redis.ini
/etc/init.d/keyhelp-php74-fpm restart
veszvs
Re: PHP Extension
Post by veszvs »
christian.john wrote: Thu 9. Feb 2023, 08:10 Hallo and welcome,
Chris
Honestly, I still don't understand how it works.
I'm used to cpanel, that I just select what I need and done.
veszvs
Re: PHP Extension
Post by veszvs »
Florian wrote: Thu 9. Feb 2023, 09:50 Hello,
cd redis-5.1.1/
make
make install
Honestly, I did not understand what you made me do ...
but it didn't work for me.
veszvs
Re: PHP Extension
Post by veszvs »
It would be nice, like on many other panels, to be able to manually select the php extensions for each php version.
Unfortunately, not all of them are very practical.
So it would be just ideal... perfect even for less experienced and practical users.
I do not know what to do...
Unfortunately, there isn't much detailed information on the keyhelp site, and there aren't any step-by-step guides online.
Re: PHP Extension
I would guess you´re probably fine with one of the additional PHP interpreters.
Only the standard OS PHP version needs some manual installations.
In the additional PHP interpreters 99,9% of common PHP modules & extensions are already included.
So far we do not really know which extentions you are missing...
veszvs
Re: PHP Extension
Post by veszvs »
Tobi wrote: Thu 9. Feb 2023, 15:19 I would guess you´re probably fine with one of the additional PHP interpreters.
Honestly, I don't even know what extension this script needs.
But I know that on cpanel, cwp and hestiacp, it can be seen correctly, while here I can't do it, I've been working on it for 10 days, I had completed the migration when I realized this very serious problem that prevents some of my apps from working.
The script must read a json file.
The script must encrypt the json file.
The script has to write the json file.
In the error log, it gives a small error, but this error also gives me on the other panels, I don't think this affects the functioning.
Could it be that some extension is missing for json to work properly?
Re: PHP Extension
veszvs wrote: Thu 9. Feb 2023, 15:38 In the error log, it gives a small error, but this error also gives me on the other panels, I don't think this affects the functioning.
Maybe, if you just post the error here.
Programmers have reason to give them names, and to print them out.
veszvs
Re: PHP Extension
Post by veszvs »
24unix wrote: Thu 9. Feb 2023, 15:45
This error:
AH01071: Got error 'PHP message: PHP Notice: Undefined index: password in /home/users/USER/www/folder/index.php on line 7'
index.php
line 7-8
$plaintext_password = $_POST['password'];
  $hash = password_hash($plaintext_password,
          PASSWORD_DEFAULT);
It looks like an error that can't recover the password.
But when I log in with my details, it works, I can log in without problems.
So as I said it's not a problem of this little error.
Re: PHP Extension
veszvs wrote: Thu 9. Feb 2023, 15:48
This error:
That is a notification, not an error.
But, yes, that is the reason that your script won't work.
index.php
line 7-8
          PASSWORD_DEFAULT);
The script expects $_POST['password'] to have a value.
It neither tests if it's empty, nor does it make any input validation.
That is very 90ies like …
Is it a script from the internet? Can we check the code?
veszvs
Re: PHP Extension
Post by veszvs »
24unix wrote: Thu 9. Feb 2023, 15:58
This error:
index.php
line 7-8
          PASSWORD_DEFAULT);
Unfortunately it is not a script that I can show in full.
I am sorry.
This error appears when I login to the index.php page.
But I don't care about that, it's the after that there are problems.
It's when the script has to fetch the contents of the json file, which are encoded and it has to decode them and save them encoded.
That's where the problem arises.
It does not work...
$prepair = file_get_contents("json/file.json");
$json_arr = json_decode($prepair, true);
array_splice($json_arr['file_info'], $delete, 1);
$newJsonData = json_encode($json_arr, JSON_PRETTY_PRINT);
file_put_contents("./json/file.json",$newJsonData);
header('Location: info.php');
As shown above... this seems to be the problem, this is where keyhelp fails.
Re: PHP Extension
veszvs wrote: Thu 9. Feb 2023, 16:03 It does not work...
It does not work is no error message.
What's in error.log?
veszvs
Re: PHP Extension
Post by veszvs »
24unix wrote: Thu 9. Feb 2023, 16:08
There are no errors in the error.log
In my opinion, It's just a shortage of php extensions.
Re: PHP Extension
Missing extension are noted in the error log.
